Airspeed to PSI Conversion
3 years 5 months ago - 3 years 5 months ago #1104 by Mark
There are many times when we have Pitot/Static leaks in lines or fittings that have to be located and replaced.
The usual practice is to isolate the line and apply pressure to it. We then use leak detector to find the problem area (presence of bubbles).
Using this method, there is always a concern of over-pressurizing the lines and splitting one open. I've used more, but ≈ 5 PSI usually is enough pressure to locate leaks.
A low pressure regulator with nitrogen can be used, but we usually just use the Pitot/Static Test Box. Using the pitot output only..... 400 Knots is a common setting.
The question arises as to what 400 Knots is equivalent to in PSI. We use a Barfield DPS1000 . The display can be changed to show different units of measure.
Knots to inches of mercury (inHg).....
The tester shows two values for inHg, Pt and Qc. A little digging was required to find the difference.....
Impact Pressure (Qc) is the pressure a moving stream of air produces against a surface that brings part of the moving stream to rest. It is the difference between the total pressure (Pt) and the static pressure (Ps). These pressure properties are related by the formula: Qc = Pt - Ps  (From Mensor.com )
The link above is worth a look. Needless to say, we want to reference Qc. Using a online conversion, we found the value 8.38 inHg to be a little over 4 PSI.
A quick PDF might help explain all this.
9 months 2 weeks ago - 9 months 2 weeks ago #1853 by Mark
Replied by Mark on topic Airspeed to PSI Conversion
Dealing with static leaks seem to be a never ending battle with the aircraft I work on.
These are all "old and worn" 767's that have a traditional Air Data Computer's.
The ADC's have two inputs, Pitot (ram air pressure from the front opening of the pitot probe used for airspeed computation), and Static (static pressure taken from the side of the aircraft or directly from ports on the pitot probe body used for altitude computation).
There is a ton of metal tubing criss-crossing the front end of the aircraft that are used to feed these pressure signals to the Air Data's.
When a tube has a hole or (most often) a "T" or elbow fitting has a crack, cabin pressure enters the line and increases sensed pressure. If a pitot line is compromised, airspeed will read high. If it's a static line, the altimeter will read low.
Finding these leaks can be difficult. We disconnect the Air Data quick disconnects (which spring seals the line shut) and apply pressure into the lines. We then go around spraying lines with leak detector looking for bubbles.
Using airspeed at 400 knots out of the Pitot/Static test box provides about (what we were guessing was about 4 PSI differential).
We experimented on our last troubleshooting venture. I have a low pressure regulator (something like this ) that I cranked full open while connected to the test box at 400 knots.
We had a reading of around 3 PSI. This was not a scientific, but it did show we really didn't get that much pressure out of the box.
We tried the regulator on its own with compressor air and dialed it up to 8 PSI. We could have gone higher, but for our find, 8 PSI was enough.
Care should be taken to not apply these higher pressures to sensors with internal mechanical bellows (Elevator Feel Computers being one), as a possible rupture could occur.
With newer aircraft..... all these lines go away. A combined Air Data and IRU unit called (of course) a ADIRU. The pitot and static ports will have a Air Data Module located near the port. This unit sends data (I'm guessing 429 data bus) to the ADIRU.
Last edit: 9 months 2 weeks ago by Mark.
9 months 1 week ago #1854 by OG GarlicSalt
Have you tried using the fluke acoustic imager to find pitot leaks? I have had good luck using it to find small leaks in oxygen as well as potable water pressure.
9 months 1 week ago #1855 by Mark
We have, but it was kinda funny.
It passed right over the leak area and I was spaying behind the person doing the scanning. I had bubbles.... when the scanner was turned back towards it.... then it showed the leak.
At 3-4 PSI input pressure, it's asking a lot for the scanner to find it.
We'll try again with 8 to 10 PSI. Maybe we'll get better results.
9 months 1 week ago #1856 by OG GarlicSalt
If i am ever unlucky enough to have to hunt a pitot leak I will try and post it here. Have had a lot of success with that equipment even finding some very very small leaks in low pressure areas. I was using it in the MEC looking for oxygen leak and it kept lighting up a zip tie on an equipment cooling duct. Pulled the zip tie to the side and sure enough micro pinhole leak there.
5 months 1 week ago #1892 by Mark
Found this in a maintenance manual dealing with elevator feel:
3 weeks 6 days ago #1908 by joshuajonesavionics@gmail.com
The reference for the knots to PSI in the manual is good. Maybe I'm reading this wrong, but you would attempt the same on the static system? Disconnect the computers, or cap the systems if they don't have quick disconnects, and apply pitot pressure from a dps-1000 to the static lines? Or would you pull vaccum?... I usually just pull vaccum as if running it up during a 91.411 to find the leaks on smaller airframes (King Airs and smaller). Doing it on the ATI/ABX 767's can be a bit more difficult using this process. The acoustic imagers/probes help if you are scanning the right spot at the right moment.
3 weeks 5 days ago - 3 weeks 5 days ago #1909 by Mark
That's exactly what we do. Isolate the Air Data by disconnecting (the fittings are self-sealing when removed).
We then apply pressure into the static system. This can be done either with the test box or low pressure regulator.
Then..... we use leak detector to spray down the lines and fittings. We'll have bubbles at the leak point.
I've tried the acoustic tester, but we have better luck with the liquid detector solution.
I've run pressure up to 8 PSI for most leak searches. Higher pressure can be used, but 8 seems to work well.
Most of our leaks are fittings, either elbow or "T". They get hairline cracks in the threads. We see this more in the winter when the aircraft are left down-powered and everything inside freezes.
Backing up to the Pitot/Static line isolation..... a schematic of the system should be consulted before starting the whole process. Every item (especially analog instruments that still use internal bellows) have to be isolated as you stated above. A full set of caps and plugs of different sizes in a box helps.
Last edit: 3 weeks 5 days ago by Mark.
Time to create page: 0.891 seconds
