Font size: + –
1 minute reading time (211 words)
Fire Loop - Interesting Find
Interesting problem today. The right engine loop 1 was showing as failed on EICAS. The system installed was a Systron-Donner.
Systron-Donner explained.
Some People Just Don't Get It
