Mark
Mark
replied to the topic
Flight deck access system
in
737 Classic
The main purpose of the flight deck access system is preventing unauthorized entry into the cockpit.
The flight crews can lock/unlock the door with a switch (usually on the overhead panel).
There is a panel on the outside of the door that a numeric pass code that can be punched in to allow the door to unlock.
View Reply
View Thread →
