SB parts accountability
1 year 11 months ago - 1 year 11 months ago #1621 by dynamics
In connection with attached file which is extracted from Boeing service bulletin regarding forward air-stair removal, is the SB only applies to the part numbers outlined in "existing part number" column?
Last edit: 1 year 11 months ago by Mark.
1 year 11 months ago #1624 by Mark
Replied by Mark on topic SB parts accountability
This is above my level.
If "I' were pulling the stairs..... the whole assembly and mounting brackets would be removed.
All these removed parts are listed as salvageable. Meaning they can be thrown away if needed.
This boils down to "if your using the stairs now" or "if there is a future need".
If that's a double "no"..... pull them out.
They add weight and make a already tight electrical compartment..... worse.
1 year 11 months ago - 1 year 11 months ago #1626 by dynamics
Replied by dynamics on topic SB parts accountability
The problem is that for some components such as "forward airstair assy", neither of tabulated part numbers apply to current fleet. Does it mean the airstair assy should not be removed to accomplish the SB??!!!
Last edit: 1 year 11 months ago by dynamics.
1 year 11 months ago - 1 year 11 months ago #1627 by Mark
I cannot answer your question. That is a engineering and quality control issue.
I am a mechanic. I choose to be a mechanic because I don't want to ever have to deal with these types of problems. Higher-ups deal with this..... not me.
Time to create page: 0.928 seconds
