• OG GarlicSalt replied to the topic ADS-B out in 737 Classic
    Set the aircraft up for a flight input the information and see if it comes up on the ADS-B radar.
    Other way would be if you can check for MODE-S Transponders required for ADS-B. Also possibly but PN of GPS antenna, if it was changed to accommodate ADS-B Out.
    I'm sure there are other ways to check as well.
