Mark
Mark
created a new forum post in
Test Equipment
Fuel Quantity Test Leads
Please reference
rotate.aero/forum/test-equipment/224-fuel-quantity-test
for fuel quantity basics and test box usage.
Please reference
rotate.aero/forum/767-28fuel/765-surge-tank-sensors
for one example of using the test box.
There is a cable connection issue when it comes to using different manufacturer Fuel Quantity Test Units.
Some, have reverse polarity BNC connectors.
On this
Viavi
box, the LoZ and Comp connectors are males. The HiZ is female.
Most co-ax test cables are male on both ends, which connect to the HiZ BNC connector.
You must have a set of special cables made up (male on one end and female on the other.....
.....or what I call "gender-bender" adapters to use for the LoZ and Comp BNC's.
These are somewhat hard to find. I ordered some from a place called
Show Me Cables
View Thread →
