Mark
Mark
replied to the topic
ATA 24-22, APU Generator
in
ATA 24, Electrical Power
Any low ohm reading should be OK. I'm guessing 5 or less.
You have an issue when it reads "open".
My readings above included the wire length from the electronics bay all the way back to the APU.
View Reply
View Thread →
© 2024 Rotate.Aero
