Mark
Mark
replied to the topic
ADS-B out
in
737 Classic
ADS-B out
www.avionix-tech.com/blog/simple-explanation-of-ads-b/
That cannot always be stated as true, but usually you’ll find most modern transponders that support TCAS will be ADS-B compliant.
’Is there a GPS input to the transponders?
A search of the part number of the transponder should answer your question.
View Reply
View Thread →
