Mark
Mark
replied to the topic
Leach Relay P/N BACR13CF2A
in
Relays
Another one.... (longer duration of 6 minutes this time).
This one controlled the Manifold Interconnect Valve for the forward equipment cooling system.
Approximately every six minutes we get a "Valve" light on the cooling control panel and a "Fwd Eqpt Valve" message on EICAS.
We had to isolate this one with engines running. 30 minutes and a 1000lbs later..... we found it.
Please reference
rotate.aero/forum/767-21cooling/380-ata-21-58-equipment-cooling
for more information on troubleshooting these types of messages.
We tested the bad relay on a power supply after removal.
View Reply
View Thread →
