Mark
Mark
replied to the topic
Testing the DC bus
in
Avionics Basics
Testing the DC bus
DC power is supplied from three transformer rectifiers.
You can measure voltage at any breaker downstream from each unit. The distribution schematics will give you guidance on how your aircraft is wired.
View Reply
View Thread →
