• Mark replied to the topic Antiskid Control Unit in 737 Classic
    As previously stated, either the system works or it doesn't.
    If you're wearing tires unevenly.... it doesn't work.
    The Fault Isolation Manual should be consulted as to what area might be causing you problems.
    Any one of the areas you listed could be causing issues.
    The "BIT" or Built In Test on the front of the unit would be the first place to go.
