Ref:
rotate.aero/forum/test-equipment/224-fuel-quantity-test
You need a PSD-60 or equivalent fuel quantity test unit. You need the appropriate break-out test cable. You need the test adapter to check individual probes at the bussing plug.
NEVER USE A CONVENTIONAL MEGGER FOR ANYTHING INSIDE THE TANK!!!
