• Mark replied to the topic Parity error-2 in 737 Classic
    This is a typical 767 SGU. The pins circled are parity pins. These go to ground, but it doesn't matter if they're hooked to each other also.
    You need to find the pins on the prints for your aircraft and find out if one is not connected.....
